Home » Audio » Source » Two turntables, two problems
Two turntables, two problems [message #13207] Mon, 11 December 2006 10:31 Go to previous message
DoctorAl is currently offline  DoctorAl
I've recently acquired two turntables at no cost, and have problems to solve with both, but would advice on which would be the better to pursue, and what the problem might be. At the moment I'm looking at vinyl as a cheap was of getting music, rather than going for super hifi stuff, so I'm not too worried about quality, and as my LPs were cheap charity shop ones, if I ultimately damage one by mistake it's no biggie.
First turntable is a Dual CS 415-2. At first the sound was very distorted, but then I spotted that the cartridge wasn't fitted into the tone arm properly. Once this was done there was a slight bit of distortion when the music is loudest. The platter doesn't really get started spinning without a push, and occasionally slowly dies in speed. The automatic start and return functions don't work - the needle has to be manually placed on and off the record. Without this, the tone arm will just fall off its support at the start, and at the end I need to manually put it back and then turn the record a few times before something clicks. If I don't do that turning, the motor won't start next time I move the tone arm over the LP.
I suspect multiple problems with the Dual, but am happy to be told otherwise!
Second turntable I was given seems to work perfectly, except the sound is always distorted worse than the Dual! It's a Technics SL-J90, rock-steady speed (in comparison with the Dual) but is just way distorted. Although neither deck appears to have adjustable tone arm weights, I did try adjusting the Technics one both ways by careful application of blu-tak, but with no improvement to the distortion, just slight differences in the sound. The actual amount of sound coming off the needle seems a lot to me, hence my suspicion that the distortion originates there.
Both decks are apparently magnetic cartridges. The amplifier is a Sony MHC-550 which is a mini system of about 1994/5 era, with Phono inputs (not adjustable for ceramic/magnetic). Obviously the Dual would probably have been the better quality one, but do any of these problems sound solvable at minimal cost?
Thanks for your help,
Al
Previous Topic: CD Turntable
Next Topic: Distortion --mistracking or damaged LP?
Current Time: Thu Nov 26 12:22:59 CST 2026
