Home » Audio » Source » Thorens TD-150 hum
Re: Ground or bad connection [message #13189 is a reply to message #13188] Tue, 05 December 2006 09:47 Go to previous messageGo to previous message
shoeihell is currently offline  shoeihell
Thanks for a reply Wayne, I was beginning to wonder if there was life out there.;-) I'm not sure I understand what you mean by "lifted the ground connection"? Everything is soldered like before....I even checked to make sure nothing it touching inappropriately. If it were the leads at the cartridge output as you suggested, wouldn't there be substantial hum when the receiver gain was turned all the way up and the motor not running? At the socket where the cart plugs in are the four soldered connections that start their runs down the arm-each of these connections have a little plastic sleeve to cover them. The hum is very background, but noticeable and only when the motor is turned on.
Previous Topic: Turntable is Skipping w/ White Noise
Next Topic: Is the sound quality of digital really as good as analoge?
Current Time: Thu Nov 05 04:48:56 CST 2026
