Home » Audio » Source » Black fluff on the stylus
Black fluff on the stylus [message #13115] Fri, 20 October 2006 11:31 Go to next message
Jonathan is currently offline  Jonathan
Hi all,
I am a bit worried as my stylus is picking up a lot of fluff when I am playing records. When I pick up and roll the fluff with my fingers, it is black (yes, my hands are clean).
This had lead me to think that my stylus is worn or chipped and was scraping off the vinyl in the groove wall, so therefore I brought a brand new stylus. However, my brand new stylus is also picking up a lot of black fluff.
I am rather concerned and would like to know if the fluff is actually chiseled vinyl or just plain old dust.
The picture shows the black fluff on my new stylus.
I hope that someone can advice me.
Thanks,
Jon
Re: Black fluff on the stylus [message #13117 is a reply to message #13115] Fri, 20 October 2006 12:27 Go to previous messageGo to next message
Go buy a record at a used record store. Play it on your turntable and see if you still get this black debris. If not, there is something about your environment or cleaning system that is making this, and your needle is picking it up. If so, then I'd be concerned the turntable is causing it and the next step would be to find out why. It can't hurt to check tracking weight and other settings too.
Re: Black fluff on the stylus [message #13118 is a reply to message #13117] Sun, 22 October 2006 05:49 Go to previous messageGo to next message
Thanks,
I'll get a record today and I'll let you know about the results tomorrow.
Jon
Re: Black fluff on the stylus [message #13126 is a reply to message #13118] Wed, 25 October 2006 06:14 Go to previous messageGo to next message
Hi,
The new record also cause the stylus to pick up a lot of fluff.
Jon
Re: Black fluff on the stylus [message #13127 is a reply to message #13126] Wed, 25 October 2006 10:42 Go to previous messageGo to next message
Sounds like maybe you need to adjust your tone arm. Hopefully that's all it is.
Re: Black fluff on the stylus [message #13128 is a reply to message #13127] Fri, 27 October 2006 07:57 Go to previous messageGo to next message
Hmmm... My tracking weight is on 1g (recommended tracking force is 1.5g) and the anti skating is on 0.
Another thing worth mentioning is that I usually play records with the dust cover opened... Is this something to look into as well?
Jon
Re: Black fluff on the stylus [message #13137 is a reply to message #13115] Sun, 05 November 2006 12:44 Go to previous message
Dewald Visser is currently offline  Dewald Visser
Hi Jon,
Get yourself a record cleaner - your records may be dirty.
Also, try getting a ONZOW Zero Dust stylus cleaner - this is the best stylus cleaner on the market today.
Regards,
Dewald
Previous Topic: Entech 205.2
Next Topic: Haplessly buzzing Pro-Ject
Current Time: Fri Nov 27 05:43:49 CST 2026
