Home » Audio » Source » Bang & Olufsen TT
Bang & Olufsen TT [message #13083] Wed, 13 September 2006 06:15 Go to next message
cleveland is currently offline  cleveland
I was wondering if someone could give me some advice. I have a 1981 Bang & Olufsen turntable in working order. I no longer use it. I am trying to find out what it is worth by looking at ebay, amazon, google, etc. But I can't really pin it down. All I can find on the unit is the number "5712" on the bottom, which isnt the model number from what I am told since no Beo 5712 exists.
...A little help?
Re: Bang & Olufsen TT [message #13084 is a reply to message #13083] Thu, 14 September 2006 09:20 Go to previous messageGo to next message
Post a photo. Maybe someone can identify it that way.
Re: Try The Site" Vinyl Engine" [message #13085 is a reply to message #13084] Thu, 14 September 2006 15:41 Go to previous messageGo to next message
nt
Re: Bang & Olufsen TT [message #13093 is a reply to message #13084] Mon, 18 September 2006 11:27 Go to previous messageGo to next message
here are the pics
I found out it is a B&O Beogram 1602
Does anyone here know enough about them to tell me this:
What would you estimate its worth to be, including an extra new stylus for this model?
Re: Try The Site" Vinyl Engine" [message #13094 is a reply to message #13085] Mon, 18 September 2006 11:29 Go to previous messageGo to next message
Re: Try The Site" Vinyl Engine" [message #13095 is a reply to message #13094] Mon, 18 September 2006 12:49 Go to previous messageGo to next message
Sorry but I don't think you will find that info on here. This is more about discussing things audio than things price wise. I would suggest you try Audiogon; they have a blue-book service that should get you a nominal value.
Re: not here [message #13096 is a reply to message #13095] Mon, 18 September 2006 12:55 Go to previous messageGo to next message
my apologies.
Re: No apology needed [message #13097 is a reply to message #13096] Mon, 18 September 2006 15:37 Go to previous message
Keep us in mind when you want to shoot the breeze about stereo stuff; I didn't mean to suggest you can't speak openly about money I just mean't to say there might not be much info.
Previous Topic: turntable buzz (grounding)
Next Topic: Turntable problem
Current Time: Sat Jun 27 02:38:23 CDT 2026
