Home » Audio » Source » Dual CS 503-1 running fast
Dual CS 503-1 running fast [message #12989] Tue, 04 July 2006 13:01 Go to next message
g11 is currently offline  g11
Just bought a Dual CS 503-1 turntable from ebay. Works fine, but tending to run slightly fast. Had a look at, and cleaned, the belt and any bits it runs round to no avail. My simple mind tells me that a worn belt would tend to run slow. Any suggestions as to how I might fix this problem would be much appreciated.
Re: Dual CS 503-1 running fast [message #12992 is a reply to message #12989] Wed, 05 July 2006 10:24 Go to previous message
It has a speed adjustment, although it is meant to be serviced by a technician and not the user so it isn't easy to get at. You might want to take it to the shop.
Previous Topic: Inexpensive Phono Stage
Next Topic: i just want something simple
Current Time: Thu Nov 05 22:39:31 CST 2026
