Home » Audio » Source » Yamaha YP-B4 sound coming is very low
Yamaha YP-B4 sound coming is very low [message #12958] Wed, 21 June 2006 10:59 Go to next message
Virgil is currently offline  Virgil
Hi,
I just acquired a Yamaha YP-B4, replaced it with a new belt and a new AT
stylus. 1- There is very little sound or no sound at all coming out. I had an ADS turntable and works fine with all my audio equipments. Does this have something to do with Magnetic or Moving coil cartridges?
2- The tonearm does not lie properly nor slide at all thru the vinyl when I press "start".
Any input will be appreciated.
Re: Yamaha YP-B4 sound coming is very low [message #12961 is a reply to message #12958] Wed, 21 June 2006 12:33 Go to previous message
You probably need a phono stage for the turntable, and moving coil cartridges are different than moving magnet types, so you need a phono stage appropriate for your cartridge. Most have settings and can work with either.
Previous Topic: Technics sl-1015
Next Topic: Stylus for Shure M111E, HE, Rat Shack RXT5, 6
Current Time: Mon Nov 30 11:04:36 CST 2026
