Home » Audio » Source » Inexpensive Phono Stage
Re: Inexpensive Phono Stage [message #12954 is a reply to message #12953] Tue, 20 June 2006 18:36 Go to previous messageGo to next message
Sure, I'd take pic --of both sides of the board if you can. I can p2p on a protoboard if need be.
Re: Inexpensive Phono Stage [message #12956 is a reply to message #12954] Wed, 21 June 2006 00:03 Go to previous messageGo to next message
Each of the Bottlehead kits I bought had C4S boards. I guess they've been including them for a few years now, since 2001 or 2002. But they're still pretty noisy, even with the C4S.
Here's one I found. [message #12967 is a reply to message #12956] Thu, 22 June 2006 21:01 Go to previous messageGo to next message
It's similar to the Black Cube, which I believe Hagtech's Bugle is based off of also.
Re: Here's one I found. [message #12969 is a reply to message #12967] Fri, 23 June 2006 00:30 Go to previous messageGo to next message
I'd be interested to know how that sounds. I'd also like to know of other tube phono stages. Keep us posted if you try any of these.
Re: Here's one I found. [message #12970 is a reply to message #12969] Fri, 23 June 2006 06:37 Go to previous messageGo to next message
The op-amp circuit looks good; similar to what I have. But it is a little more complicated. I have the circuit here but my dog ate the end of the scanner cord. So as soon as I get around to replacing it I can send a pic.
Another one you might want to look at because it already has a PC designed for it is ESP's version. His stuff is well regarded although I haven't heard that one myself.
Re: Here's one I found. [message #12971 is a reply to message #12970] Fri, 23 June 2006 08:55 Go to previous messageGo to next message
MB - Do you have a web link for ESP's? Can't seem to find it.
Re: Here's one I found. [message #12972 is a reply to message #12971] Fri, 23 June 2006 12:01 Go to previous messageGo to next message
This might work and you can try Elliot Sound Products. He has the most thorough and well documented as well as good solid engineering practice site concerning audio around. His PC's though are a little flimsy but very inexpensive. Usually 15$ gets you a PC for a project.
Heathkit WA-P2 [message #12975 is a reply to message #12972] Tue, 27 June 2006 12:24 Go to previous messageGo to next message
My grandfather had a Heathkit W5M amp with the WA-P2 pre for it when I was a kid. I happen to have the kit manual for the preamp. Is this design any good? I realize it would need a PS made for it since they actually ran off the amp's PS.
Re: Heathkit WA-P2 [message #12976 is a reply to message #12975] Wed, 28 June 2006 13:11 Go to previous messageGo to next message
I can only say this; they don't have the greatest reputation. Thats from scuttlebutt; not my personal experience but it seems to be a pretty universal opinion.
Are you still looking for the Phono stage?
Re: Heathkit WA-P2 [message #12977 is a reply to message #12976] Wed, 28 June 2006 15:30 Go to previous messageGo to previous message
Well, that's what I figured.
Yes, I'm still trying to decide what I want to do. I've got an old Carver Receiver as well as the Kenwood integrated (which is my living room amp that has a phono stage) so I can get by with those for now I guess. But I believe that any of the DIY like Hagtechs are better than the one in the Kenwood more than likely.
Previous Topic: Yamaha Turntable History
Next Topic: Dual CS 503-1 running fast
Current Time: Thu Nov 05 23:19:56 CST 2026
