Home » Audio » Source » Noise during playback
Re: Used records and DIY RCM [message #12912 is a reply to message #12910] Sun, 04 June 2006 17:18 Go to previous messageGo to previous message
The few new records I've bought, mostly Classic have been full of pops. I get good quality used at record shows and occasionally, Goodwill. Some are still sealed. Generally the re-issues.
All clean up to relative quiet wiyh a very few exceptions.
You get a long crevice tool with the Shop Vac. Plug the opening at the end with caulk. Cut a narrow slot the length of the flat part of the tool. I used my table saw very precariously; a Dremel might be safer.
Cut 2 narrow strips of the paint pad refill and glue on either side of the slit. Work 3 or 4 drops of the RRL around on the record with a carbon fiber brush. The Audioquest clone from garage-a-records is perfect. You'll have to thoroughly wet the brush and then a few more drops gets the record wet enough. Vacuum 2 or 3 rotations and repeat. let dry 20 minutes.
Previous Topic: New Turntable Advice
Next Topic: Remember this ugly Bugle phono stage from the swap meet?
Current Time: Mon Oct 26 08:48:16 CDT 2026
