Home » Audio » Source » Technics 1200 Output Problem
Technics 1200 Output Problem [message #12883] Mon, 08 May 2006 21:50 Go to previous message
Mention is currently offline  Mention
I have a Technics 1200mk2 that I bought used. The problem is that there is only audio on the left channel, and nothing from the right. I've tried different cartridges and head shells, they all work fine on my other table, and all have the same problem on the problem table.
The guy I bought the table from changed out the rca cable, so I'm thinking that is probably the problem. I dont have a volt meter, so I'll check the power out tomorrow. Anything else that I might want to look at? I opened the table up, and the replacement RCA looks ok, all the solder points appear good.
thanks!
Previous Topic: DN990r md recorder error codes on used gear?
Next Topic: Numark mixer cuts out after every track
Current Time: Thu Nov 05 12:23:05 CST 2026
