Home » Audio » Source » Manualblock
Manualblock [message #12797] Sun, 19 February 2006 01:09 Go to next message
MWG is currently offline  MWG
Your advice motivated me to drag out the old 1229 and switch it into another base and put a M97xE in it and now I have decent sound. Gone is the rumble and resonance of the cheap Denon. Thank you for your advice and patience
Re: Manualblock [message #12798 is a reply to message #12797] Sun, 19 February 2006 09:39 Go to previous messageGo to next message
Hey I'm glad it worked out for you. Don't think twice; I'm sure I'll nedd your advice one day.
Did you crazy glue the Shure to the cartridge body? That makes a huge difference in sound.
Re: Manualblock [message #12799 is a reply to message #12798] Sun, 19 February 2006 09:53 Go to previous messageGo to next message
I've never heard of that. What exactly does this do for it?
Re: Manualblock [message #12801 is a reply to message #12799] Sun, 19 February 2006 17:12 Go to previous message
On the microscopic levels that the groove exists in even a slight rattle of the stylus body can smear some HF signals. So by taking a toothpick with a couple drops of crazy glue and gently securing the stylus body to the cartridge body you tighten up the whole cartridge as a unit.
It seems to me to make the sound a little more detailed and smoother.
Previous Topic: dvd mod/upgrade
Next Topic: Any thoughts on a Denon DP-2000?
Current Time: Fri Nov 06 04:42:12 CST 2026
