Home » Audio » Source » Cartridge
Cartridge [message #12679] Wed, 07 December 2005 20:20 Go to next message
Anonymous is currently offline  Anonymous
Hello to all,
Well, I should say that I made my decision to buy a Technics SL 1200 turntable, as was also suggested by manualblock, here: http://audioroundtable.com/Turntable/messages/1247.html.
I have a question about the many cartridges available out there.
I have always been thinking about an Ortofon OM 30 cartridge, which is a magnetic one. I have to think further and particularly thinkg about a moving coil cartridge. Can they really be better, even if more expensive?
Re: Cartridge [message #12877 is a reply to message #12679] Fri, 28 April 2006 00:48 Go to previous message
KARL VEE is currently offline  KARL VEE
Your answer is YES, a moving coil is that much better. Keep in mind not only the higher cost of the cartridge but you may also require a Pre-Pre amp or transformer. Some of the moving coil cartridges have a lower output and require this step-up unit unless your amp has an input for moving coil. Another factor, some cartridges must be returned to the factory for stylus replacement.
Previous Topic: Thorens TD 105 - HELP!!!!!!!!!
Next Topic: Turntable "skipping" - Help!
Current Time: Sat Nov 07 16:54:27 CST 2026
