Home » Audio » Source » turntable problems
turntable problems [message #12616] Fri, 18 November 2005 10:53 Go to next message
Theresa is currently offline  Theresa
I just bought a Denon DP-32F at ebay. It works fine. The problem is, though, that the sounds I get is too bass heavy, as it were. If I play certain records (club music, everything that is produced with multiple layers of bass) my speakers begin rebelling and it has nothing to do with volume. The problem doesn't occur with digitalised tracks.
Does anyone have an idea what to do?
Thank you
Re: turntable problems [message #12617 is a reply to message #12616] Fri, 18 November 2005 11:57 Go to previous messageGo to next message
The tracking force is too heavy. You need to back off on the adjustment some.
Re: turntable problems [message #12619 is a reply to message #12617] Fri, 18 November 2005 15:33 Go to previous messageGo to next message
That doesn't do the job unfortunately. Any other suggestions?
Re: turntable problems [message #12620 is a reply to message #12619] Fri, 18 November 2005 16:49 Go to previous messageGo to next message
Which cartridge do you have on the tonearm?
Re: turntable problems [message #12636 is a reply to message #12620] Mon, 21 November 2005 21:04 Go to previous messageGo to next message
ortofon LM20 14
Re: turntable problems [message #12638 is a reply to message #12636] Mon, 21 November 2005 21:25 Go to previous messageGo to next message
It seems to be a problem of the cartridge/stylus. What kind of cartridge/stylus would be a good choice for also playing well produced club music?
Re: turntable problems [message #12639 is a reply to message #12638] Tue, 22 November 2005 10:33 Go to previous messageGo to next message
Stanton 500ls; should be able to get it for about 55$. Then glue the stylus to the body with a tiny dab of crazy glue.
Re: turntable problems [message #12640 is a reply to message #12639] Tue, 22 November 2005 10:48 Go to previous messageGo to next message
thank you!
Re: turntable problems [message #12641 is a reply to message #12640] Tue, 22 November 2005 13:16 Go to previous message
My pleasure; keep us informed!
Previous Topic: Speed too fast
Next Topic: Denon turntable dust covers
Current Time: Mon Oct 26 01:43:38 CDT 2026
