Home » Audio » Source » Dual CS508 Sounds terrible
Re: Dual CS508 Sounds terrible [message #12403 is a reply to message #12402] Tue, 02 August 2005 12:10 Go to previous messageGo to previous message
What you describe does not soundlike a bad bearing. It sounds like a poor quality contact between the cartridge pins and the leads. If you can clean and gently dis-connect and gently re-connect the leads to the cartridge pins I think you may find some improvement.
Or the cart is just bad and worn out. Try the leads and also while your at it if you can replace the RCA jacks or clean them too. Which phono stage do you use?
Previous Topic: Well, anyway Shure vs. Ortophon
Next Topic: What Shakespeare said about vinyl and digital.
Current Time: Sun Nov 08 06:34:34 CST 2026
