Home » Audio » Source » 1200mk2 pitch control re-set?
1200mk2 pitch control re-set? [message #12291] Mon, 27 June 2005 21:31 Go to next message
Damanegi is currently offline  Damanegi
I wanted to know if there's anyway to reset the pitch control speed to the factory setting.
I tweaked the pitch control a while back but I can't set it to make it work like the original setting, please help, I would appreciate any suguestions. Thank you.
Re: 1200mk2 pitch control re-set? [message #12292 is a reply to message #12291] Tue, 28 June 2005 07:41 Go to previous messageGo to next message
Where did you tweak the control; on VR 301/201 or VR302? You may have to balance the pitch control with the brake adjustment. Let us know how it was tweaked and we may be able to help. The Pitch Control Gain Adjustment is probably where you are misadjusted. Do you have a schematic? It is just a simple pot but it affects all three settings.
If you can get to the three adjustments it should be simple. Are you good with mechanics?
Re: 1200mk2 pitch control re-set? [message #12293 is a reply to message #12292] Tue, 28 June 2005 07:44 Go to previous message
Sorry you may need a ohmeter to test the resistance on the pitch control PCB. There is a connector that allows you to fine tune that measurement. Let us know.
Previous Topic: Need help understanding my Museatex BIDAT manual (Ed Meitner)
Next Topic: Record cleaning product
Current Time: Thu Nov 19 11:07:09 CST 2026
