Home » Audio » Source » around the last few songs, my stylus won't move on? can someone help?
Re: Hi-Fi News Test Record [message #12277 is a reply to message #12276] Sun, 19 June 2005 11:06 Go to previous message
Anti-skating should provide a small lateral force on the tone arm. If the bearings are free moving, then the arm should move when balanced. But if the arm lift is used, there will be enough friction between the rubber on the lift and the tone arm to prevent movement. You'll have to use the balance weight and set it so the arm is free-floating to see any movement from anti-skating force.
Previous Topic: Is Mobil 1 100% safe to use with my Thorens? First hand experiences apreciated :-)
Next Topic: why is a reissue not as good as an original pressing in good condition?
Current Time: Thu Nov 05 18:43:05 CST 2026
