Home » Audio » Source » Stereo with no adjustable counterweight
Stereo with no adjustable counterweight [message #12248] Sun, 12 June 2005 21:29 Go to next message
LRP is currently offline  LRP
Hi all,
I recently purchased an old cabinet stereo at a garage sale, and would like to be able to use it. I have leveled it; everything appears to be fine in that respect. However, the tonearm has no adjustable counterweight, and I'm therefore having a heck of a time balancing it. Does anyone know how this is done for such a machine? Thanks in advance.
Luke
P.S. Pictures are here and here. Thanks again.
Re: Stereo with no adjustable counterweight [message #12249 is a reply to message #12248] Sun, 12 June 2005 22:04 Go to previous messageGo to next message
Looks like a turntable with an old ceramic cartridge on a non-adjustable tone arm.
Re: Stereo with no adjustable counterweight [message #12251 is a reply to message #12249] Mon, 13 June 2005 00:54 Go to previous messageGo to next message
Hi again,
Unless anyone has other suggestions, would I be correct in concluding that I should probably have a shop look at this? Thanks again.
Luke
Re: Stereo with no adjustable counterweight [message #12252 is a reply to message #12251] Mon, 13 June 2005 01:36 Go to previous message
It sure couldn't hurt to have the unit looked over, but if it's working there is nothing more the shop will do for you. The set-down weight of the arm is not set by counterweight. There is no adjustment that is done for a turntable like this. The only user-serviceable items are the needle and the idler wheel, so you can expect to replace them every once in a while and that's about it.
Previous Topic: BIC 80z and Voice of Music 369-2
Next Topic: Linn LP 12 Transformer/Turntable modifications
Current Time: Fri Nov 06 00:15:35 CST 2026
