Home » Audio » Source » Question regarding setting up / tweaking of SME 3009/S2
Question regarding setting up / tweaking of SME 3009/S2 [message #12238] Sat, 11 June 2005 19:32 Go to previous message
Kuja is currently offline  Kuja
Hi,
I have this question regarding setting up my SME 3009 improved (removable headshell version).
When I got my Thorens 126 MkI / SME 3009 some twenty years ago (those were times without the Internet) I was told by some "guru" that SME headshell was not that good and that I should do the following tweak:
I stuffed it with a small amount of some sort of black modelling putty (feels like BluTack), filling all small holes. The cartridge at that time was MM Ortofon VMS30 MkII.
I kind of remember that after this tweak, sound got warmer with slightly deeper bass. After twenty years I'm not really sure about the difference, since I never removed the putty...
Question No 1: Is this tweak valid in your opinion?
Question No 2 (also related to Q No 1): I allways wondered what this really is for:
SME 3009 has this setting for cartridge weight. Why? On some other arms you only have VTF and anti-skating settings.
I used to set this to naked cartridge weight. I always checked the VTF with a small Ortofon Stylus Gauge.
Recently, I started wondering if the cartridge weight setting should also reflect added weight of spacers, screws and this putty? Should I also substract the weight of the finger lift thingy that I removed from the headshell?
The cartridge I'm using now is high output MC - Ortofon MC-1 turbo. It is only a temporay solution, since I'll receive my new Shure V15 V XMR in a few days
Thanks,
Aleksandar
Previous Topic: Bill, whats the latest on your dynavector?
Next Topic: DV 10X5; 10X$$$, 5X as good
Current Time: Fri Nov 06 00:36:41 CST 2026
