Home » Audio » Source » Analogue Belt drive turntables/Platine Verdier
Analogue Belt drive turntables/Platine Verdier [message #12191] Fri, 27 May 2005 02:20
Continuing with the Platine Verdier. The motor is sourced from philips but it is not just any run of the mill production motor.It is called a "Low inertia motor",In a low inertia motor the rotor consists of a copper coil; the turns almost parrallel with the rotational axle cutting the field lines of the magnetic circuit,excited by a permanent magnet that is totally fixed. The magnets are mettallic alloy and the brushes and collector are gold-plated.
The rotor turns in fitted and self-lubricating bronze bearings. The motor is DC powered with a simple regulatory circuit that obtains perfect stability.
Sometimes it is good to see why the very expensive belt-drives cost as much as they do.
Previous Topic: Surprising development concerning dust covers on your turntable...
Next Topic: High End Turntables
Current Time: Thu Nov 05 06:25:15 CST 2026
