Home » Audio » Source » How does the project rate?
How does the project rate? [message #12107] Sat, 23 April 2005 09:30 Go to next message
Bob is currently offline  Bob
is it good or bad? and which model is best value. are the earlier ones good?
Re: How does the project rate????? [message #12133 is a reply to message #12107] Fri, 29 April 2005 22:38 Go to previous messageGo to next message
can someone tell me which pro-ject TT is best to get? I might just save a bit more and get one of these but im not too sure which one to get. Some of them have the pre amp already in them and i think the project 2 makes you manually change the speed by lifting the turntable off n stuff, most of the lps are in the same speed though right, so it might just be for a couple of eps or something. So takin into consideration all this whats best value for under US$400 or so? THANKS.
Re: How does the project rate????? [message #12151 is a reply to message #12133] Mon, 09 May 2005 01:37 Go to previous message
Somebody? Like should i just get the simple project debut III, caus it cost the cheapest, or is it crap?
Previous Topic: Sony LX250H BIG Problem
Next Topic: how do I find the value of my Dual 731Q
Current Time: Thu Nov 05 08:31:41 CST 2026
