Home » Audio » Source » Rega Elys cartridge
Rega Elys cartridge [message #12118] Mon, 25 April 2005 04:01 Go to next message
Carlos Banha is currently offline  Carlos Banha
Last night I forgot to turn off my Rega Planar P3. It was turning continuously about 10 hours. Could the it damage the cartrige (Elys Rega?, with only few months of regular use. It is safe play records records with this cartridge or should I replace immediatly cartridge?
Re: Rega Elys cartridge [message #12119 is a reply to message #12118] Mon, 25 April 2005 06:30 Go to previous messageGo to next message
Was the needle in contact with the paper label?
Re: Rega Elys cartridge [message #12120 is a reply to message #12118] Mon, 25 April 2005 06:32 Go to previous messageGo to next message
I've got an Elys and a Rega P2. If the motor was running but the tone arm was on its perch, you won't suffer any consequences. If the needle was in the groove, well, you've added ten hours of wear to the needle and the record's exit groove.
Re: Rega Elys cartridge [message #12121 is a reply to message #12118] Mon, 25 April 2005 09:09 Go to previous messageGo to next message
Unless it hit the label paper; which means it is probably worn out since the paper acts like sandpaper. If so I would replace it. If not then Wayne is correct.
Re: Rega Elys cartridge [message #12123 is a reply to message #12119] Mon, 25 April 2005 09:45 Go to previous message
No it wasn't.
Previous Topic: whats a cheap turtable i can get?
Next Topic: technics 1200's
Current Time: Thu Nov 05 19:24:47 CST 2026
