Home » Audio » Source » Do I need a Phono pre-amp box???
Do I need a Phono pre-amp box??? [message #11967] Tue, 01 March 2005 22:36 Go to next message
Luke is currently offline  Luke
Hey fellas, just brought a Pro-Ject Debut II for $AU380
It has an onboard phono stage, but do i need a phono pre-amp box to run through a Mini Hi-Fi Video input. I get signal, but bugger all level. I just don't want to spend the money on a pre-amp box if it wont bring the level up at all. Thanks for the help.
Re: Do I need a Phono pre-amp box??? [message #11969 is a reply to message #11967] Wed, 02 March 2005 09:24 Go to previous message
If it has an onboard phono stage you should be able to use a line level input. If you are not getting volume then check another line input to see if the phono stage is working. If you plug in an outboard phono stage from the existing onboard stage nasty stuff happens.
Whats bugger all?
Previous Topic: 58 Crown Imperial Tape Recorder
Next Topic: Turntable thrust bearing (replacement) alternative
Current Time: Thu Nov 12 03:27:55 CST 2026
