Home » Audio » Source » Turntale won't turn?
Re: Turntable won't turn? [message #11955 is a reply to message #11934] Mon, 21 February 2005 23:35 Go to previous message
John Chleapas is currently offline  John Chleapas
Try emailing or better yet call garage-a-records. It is one of the links below to get you going in your search. Also keep in mind you will need a new stylus before you destroy any playable records on your new t/table if the stylus is NFG.
On Ebay buying it is VERY risky. Sadly most sellers have no clue how to properly pack and ship a turntable. Perhaps use the advanced search feature on ebay to limit yourself to only tables in your state. Or look at AudioGon for tables near you. in my area is the WantAdvertiser that has used stereo gear for sale, also try the Craigslist. It is far safer to buy something close to you to avoid heartache when the box arrives with a smashed table due to improper packaging. Good luck! John C.
Previous Topic: How Often Do YOU Lube platter shaft / motor?
Next Topic: YAHOO!! Got the Ariston RD-11 Superieur set up and playing TUNES
Current Time: Fri Nov 06 01:03:07 CST 2026
