Home » Audio » Source » technics sl-1600 outputs in mono (please help!)
technics sl-1600 outputs in mono (please help!) [message #11917] Wed, 09 February 2005 15:08 Go to next message
Charlie is currently offline  Charlie
Hey, I have an old technics sl-1600 that will only output the left channel. Switching the left and right plugs has no effect. Oddly, it outputs the left channel to both speakers..any ideas? If it's the cartridge, what kind of cartridge would be a good replacement. Thanks for any help.
Re: technics sl-1600 outputs in mono (please help!) [message #11918 is a reply to message #11917] Wed, 09 February 2005 15:14 Go to previous messageGo to next message
Redo the wiring on the cart. Then see what happens.
Re: technics sl-1600 outputs in mono (please help!) [message #11932 is a reply to message #11918] Sun, 13 February 2005 12:07 Go to previous messageGo to next message
Hey, do you think I should buy new wires? If so, what gauge? Thanks
Re: technics sl-1600 outputs in mono (please help!) [message #11933 is a reply to message #11932] Sun, 13 February 2005 15:43 Go to previous messageGo to next message
Are your wires in bad shape? If not then I wouldn't be too concerned.
Re: technics sl-1600 outputs in mono (please help!) [message #11965 is a reply to message #11933] Thu, 24 February 2005 10:55 Go to previous message
they look fine...so do you think that just resaudering them might help?
Previous Topic: Turntable Set-up. Anyone want a job?
Next Topic: 58 Crown Imperial Tape Recorder
Current Time: Fri Nov 06 00:27:14 CST 2026
