Home » Audio » Source » Tracking Force
Re: Tracking Force [message #11896 is a reply to message #11895] Fri, 04 February 2005 10:28 Go to previous messageGo to previous message
Cooper338 is currently offline  Cooper338
Yes, I believe this cartridge is designed for DJ use. I've done exactly what you suggested: use the stylus force guage to set the cartridge at 3 grams, and then tweak it just a bit higher. It sounds very good at that setting, so maybe I'll just leave well enough alone. But, the Stanton might well be worth looking into. Thanks for the recommendation.
Previous Topic: My latest AR Mod/platter mat
Next Topic: HELP! my counterweight broke off
Current Time: Sun Oct 25 21:09:26 CDT 2026
