Home » Audio » Source » turntable troubles...
Re: turntable troubles... [message #11863 is a reply to message #11862] Mon, 24 January 2005 18:54 Go to previous messageGo to previous message
I Have heard that sound resulting from a dirty stylus. I would try cleaning first. Then make sure the table has not been moved or shifted unknowingly and caused severe unbalance. Then the stylus pressure or tracking force, set it correctly and make sure it is right. Then follow up with standard troubleshooting practice. Wayne is correct except I would try the simple things first.
Previous Topic: Turntable problems
Next Topic: digital to digital converter ?
Current Time: Tue Sep 22 00:24:38 CDT 2026
