Home » Audio » Source » Significant upgrade
Re: Significant upgrade [message #11833 is a reply to message #11832] Thu, 13 January 2005 09:25 Go to previous messageGo to previous message
Interesting, I have a similar "wall mount rack" except I went with your basic black home depot brackets. What is anti fatigue mat? I see you have some screws attaching the board to the bracket. Are these screws just loosely in place to prevent the board from being knocked off? Seems like if they are tightened or in contact with the sides off the sides of the bracket holes it would "short circuit" the dampening effect of the yellow stick stuff? One other question, having a similar rack, how do you level the board? I have small cork pads the board rests on and place a few cardboard spacers as needed. I mounted it as level as possible to avoid as much adjustment as I could. Does the yellow stuff give enough "crush" to allow this adjustment? Just wondering.
Russellc
Previous Topic: itunes sued
Next Topic: Benchmark Dac-1 Reviewed in Sensible Sound
Current Time: Thu Nov 05 21:48:16 CST 2026
