Home » Audio » Source » Significant upgrade
Significant upgrade [message #11832] Thu, 13 January 2005 03:20 Go to previous message
Part of my prep for the new table was trying to isolate it's shelf from vibration.
The metal shelf brackets had just been "mollie'd" to the drywall. I removed them, cut strips of the 3/4" thick anti-fatigue mat as long as the vertical part that touches the wall and re-installed them with "lag" screws into the studs. Then I put that yellow "poster-tak" stuff on the horizontal part for the shelf to rest on.
Now the bracket is isolated from the wall and the shelf isolated from the bracket.
Major difference! What I thought was WOW must have been the result of vibration. Where voices had a kind of "victrola" tone now they are clear. Bass is better defined.
Vibration is everything! Can't wait for Sunday. Stay tuned.
Previous Topic: itunes sued
Next Topic: Benchmark Dac-1 Reviewed in Sensible Sound
Current Time: Thu Nov 05 19:29:09 CST 2026
