Home » Audio » Source » anti-skate
anti-skate [message #11796] Thu, 23 December 2004 10:29 Go to next message
d'rimple is currently offline  d'rimple
Just and idle thought here. A quick search found nothing on this specifically. Perhaps it's been explained away quite readily, but...
wouldn't the most foolproof and accurate anti-skate remedy simply be a calculated tilt of the entire turntable? Perhaps some form of chart would be available to determine the degree as a factor the stylus tracking weight?
Just a thought.
Re: anti-skate [message #11797 is a reply to message #11796] Thu, 23 December 2004 10:35 Go to previous messageGo to next message
My post seemed to have disappeared. Just checking
Re: anti-skate [message #11798 is a reply to message #11797] Thu, 23 December 2004 16:57 Go to previous messageGo to next message
One of the guy's who worked on the Platine Verdier' used to advocate that very thing. The problem is the angle is fixed so as the grooves narrow the arm speeds up and changes the thrust force against the groove sides. Spring loaded bias attempts to compensate for the change.
Re: anti-skate [message #11799 is a reply to message #11798] Thu, 23 December 2004 20:28 Go to previous messageGo to next message
Do the grooves actually narrow, or does it result from the angle of "attack" of the outside of the groove becoming more acute toward the center? If so, I guess that would indicate a need for some progressive restraint. Can it be that measurably different from the outside to the inside groove? Has anyone measured this?
Re: anti-skate [message #11800 is a reply to message #11799] Fri, 24 December 2004 05:50 Go to previous messageGo to next message
These inquiries would be answered in The Vinyll Engine forum. They are dedicated to Vinyll and have lots of tutorials and such that go into depth on each topic. I only mention it because they have been a great help to me on some of this stuff.
To answer your question the grooves do narrow and the angle becomes more acute resulting in greater side thrust on the inside groove. The old issues of the Tracking Angle magazine had a 20 page white paper on bias settings for tonearms. I believe it is still available as a download on the net. Free of course. I know they took before and after electron microscope photos of the groove of a record to show the effects of this.
Re: anti-skate [message #11804 is a reply to message #11798] Sat, 01 January 2005 13:49 Go to previous message
kyle is currently offline  kyle
I don't think the grooves are narrower at any point on a record. Perhaps you mean that the diameter of the groove reduces as you get closer to the center. Why would the arm speed up?
Previous Topic: Help on MP3-CD playback?
Next Topic: sony PS-LX250H drive belt
Current Time: Wed Oct 21 10:48:05 CDT 2026
