Home » Audio » Source » Turntable problems
Turntable problems [message #11781] Tue, 14 December 2004 16:23 Go to next message
Q is currently offline  Q
My turntable has begun to give me problems. I'm only gettting sound from one speaker - this doesn't happen when I play cds or the radio.
Any thoughts on what direction I should go?
Thanks in advance,
Q
Austin
Re: Turntable problems [message #11782 is a reply to message #11781] Tue, 14 December 2004 16:43 Go to previous messageGo to next message
First swap the RCA output leads from left to right and see if the same speaker still has no sound. If the same speaker is still silent, you need to Borrow another Turntable to see if the Phono Stage in your set-up is functioning. If that doesn't change anything then the problem is most likely your phono cartridge. That will need to be replaced. Tell us how old the needle and cartridge is please.
Re: Turntable problems [message #11859 is a reply to message #11782] Sun, 23 January 2005 12:59 Go to previous message
Steve B. is currently offline  Steve B.
Thanks!!! It was not my initial posting but still, it was my turntable question. No longer a problem, your advice solved my "JVC JL-F50" problem. Thanks again!!!!
Previous Topic: My first "new" LP in 20 years; what a disappointment
Next Topic: turntable troubles...
Current Time: Thu Nov 05 22:24:36 CST 2026
