Home » Audio » Source » sony PS-LX250H drive belt
sony PS-LX250H drive belt [message #11554] Sun, 11 April 2004 18:14 Go to next message
dramius is currently offline  dramius
During a move, the drive belt somehow got knocked off, and i have no idea where to put it back on. I went to online support, they we're morons and told me to look at the wrong page of the manual, looked at the manual, the diagram was of low quality and said nothing about the entire drive belt setup.They told me to ship it to their repair center and i don't have that kind of money.I was wondering if anyone could tell me how to put it back on?
Re: sony PS-LX250H drive belt [message #11557 is a reply to message #11554] Wed, 14 April 2004 08:54 Go to previous messageGo to next message
I'm not familiar with that turntable. But I think I might be able to help, if it's like other turntables. Check this and see, is there a rubber mat under which you find a metal platter? If so, are there holes in the platter that you can see inside? This is common on many belt-drive turntables.
If this is the case on yours, you will want to remove the platter and place the belt around the belt path on the platter, gently holding the belt through the access holes. Place the platter back on the spindle and thread the belt over the drive motor pulley. Stretch the belt as little as possible when you do this.
I hope that helps and you're back in business.
Re: sony PS-LX250H drive belt [message #11564 is a reply to message #11557] Fri, 16 April 2004 01:09 Go to previous messageGo to next message
THANK YOU SO MUCH!!!!!!!!!
Re: sony PS-LX250H drive belt [message #11565 is a reply to message #11564] Fri, 16 April 2004 06:10 Go to previous messageGo to next message
Sure, no trouble at all. Did you get the belt back on?
Re: sony PS-LX250H drive belt [message #11572 is a reply to message #11565] Wed, 21 April 2004 06:31 Go to previous messageGo to next message
sure did thanks alot.
Re: sony PS-LX250H drive belt [message #11748 is a reply to message #11572] Thu, 02 December 2004 10:56 Go to previous messageGo to next message
Sunixx is currently offline  Sunixx
Thank you! this has helped me too, i was hoping i wasn't the only one, thankyou so much!!!
Re: sony PS-LX250H drive belt [message #11805 is a reply to message #11748] Sat, 01 January 2005 15:59 Go to previous message
Dorian is currently offline  Dorian
This helped me tons too! Thanks!
Previous Topic: anti-skate
Next Topic: for manualblock -- Yamaha RP u100
Current Time: Wed Oct 21 11:47:00 CDT 2026
