Home » Audio » Source » Turntable thrust bearing (replacement) alternative
Re: Turntable thrust bearing (replacement) alternative [message #11731 is a reply to message #11730] Fri, 12 November 2004 09:27 Go to previous messageGo to previous message
DanR is currently offline  DanR
The Garrard Lab 80 is an idler-driven unit. The use of the Teflon-on-Teflon washers should work on any type of turntable where there is a separate platter thrust-bearing. Direct-drives might have the turntable drive spindle directly coupled to the motor -- not sure -- someone on this forum site will know about that.
However, as long as the thickness of the original thrust-bearing is matched fairly closely by the thickness of the Teflon washers (might need more than two stacked or a thicker stock), this fix should work nicely.
Let me know how this works out if you are able to apply this remedy.
Previous Topic: Do I need a Phono pre-amp box???
Next Topic: Systemdek 2 bearing
Current Time: Fri Oct 02 08:49:25 CDT 2026
