Home » Audio » General » AC/DC Electronics
AC/DC Electronics [message #1161] Fri, 17 December 2004 17:08 Go to next message
In the spirit of education and electronics; is there a simple explanation of exactly how and why there can be a DC component riding on an AC waveform? Thanks, J.R.
Re: AC/DC Electronics [message #1163 is a reply to message #1161] Sat, 18 December 2004 00:17 Go to previous messageGo to next message
Instead of having an AC signal with zero crossing at 0 volts, shift it to whatever the DC level is. That is a description of an AC signal riding on a DC one.
If you think about it, there is always a DC component. Whatever the zero crossing average is, that's the DC value. If it is exactly the same as your reference, then you might consider it to have no DC component, or zero volts. But if you reference it to something else, there may be some DC offset.
Re: AC/DC Electronics [message #1164 is a reply to message #1163] Sat, 18 December 2004 02:44 Go to previous messageGo to next message
How do I know what the DC level is?
Re: AC/DC Electronics [message #1165 is a reply to message #1164] Sat, 18 December 2004 06:42 Go to previous messageGo to next message
With an oscilloscope, set the input for DC coupling. You'll see an offset, and that reflects the DC level. If all you have is a DVM, you could use a 1Kohm resistor in series and a large capacitor after that in shunt to filter out the AC. The DC level is all that will remain, so just measure it with the DC voltage setting on your meter.
Re: AC/DC Electronics [message #1166 is a reply to message #1165] Sat, 18 December 2004 07:59 Go to previous message
Excellent; thanks Wayne.
Previous Topic: P.C. Audio
Next Topic: is this wayneparham.com?
Current Time: Thu Nov 05 04:45:48 CST 2026
