Home » Audio » Source » Question About Sony PS-LX220
Re: Question About Sony PS-LX220 [message #11622 is a reply to message #11586] Wed, 02 June 2004 19:05 Go to previous message
Grayson Lassor is currently offline  Grayson Lassor
If you get no answer using Wayne's idea try this;
Swap turntable's phono leads at amp, if problem switches
channels, turntables connections at cartridge or elsewhere
are bad or phono cable connection is bad or "loose'(solder).
Phono cable may be bad (open)If problem does't change channels
amp is probably at fault. Of course cartridge may be bad.
Hope you solve problem. glassor Grayson Lassor
Previous Topic: squash'ed balls
Next Topic: Audio Note Kits are Back
Current Time: Sat Nov 21 18:19:45 CST 2026
