Home » Audio » Source » Hagerman Bugle
Hagerman Bugle [message #11528] Mon, 08 March 2004 21:08 Go to next message
I've been running this op amp based Phono Amp on two 9V and the sound's been pretty good. However, I built the +/-15V regulated power supply over the weekend, and now the turntable rocks! With battery power, it gave off a very warm, relaxed and lush sound. The extra headroom from the power supply punches it up several notch.
The platter geeks are right. Vinyl can sound awesome!
Highly recommended for anyone looking for an excellent DIY box for under $100. I've already collected parts for the tube based Cornet and hope to complete it by Spring.
Gar.
Re: Hagerman Bugle [message #11529 is a reply to message #11528] Tue, 09 March 2004 08:59 Go to previous messageGo to next message
Pretty cool!
Did you use a 7815 and a 7915 for your supply?
Re: Hagerman Bugle [message #11530 is a reply to message #11529] Tue, 09 March 2004 09:21 Go to previous messageGo to next message
Both. 7815 for the positive rail, 7915 for the negative rail as per Hagerman's design.
Re: Hagerman Bugle [message #11531 is a reply to message #11530] Tue, 09 March 2004 10:52 Go to previous message
Yep, yep. That's what I thought. When I need only an amp or less at 5, 12 or 15 volts, I use 7xxx regulators. A 7xxx regulator, bridge rectifier, transformer and a couple of electrolytic caps and you have an excellent little regulated supply.
Previous Topic: AR XB1 running again
Next Topic: Non-oversampled 16 bit DAC
Current Time: Tue Nov 03 15:31:17 CST 2026
