Home » Audio » Thermionic Emissions » Looking for good 20 watt amp design to drive Jordan TL's?
Re: Damping factor - SE vs. PP [message #11226 is a reply to message #11224] Wed, 12 October 2005 16:48 Go to previous messageGo to previous message
Steve is currently offline  Steve
>>"we can`t say that rp (and Zout) of SE amp vary wildly like in your example."
It might be partly symantics Damir, so I will say the output Z and subsequent Damping Factor changes "somewhat".
Even with a relatively horizontal loadline, the plate current should be held as high as possible, or keep the power down so the signal doesn't swing near the tube's cutoff.
Specs from 300b data sheet (since that is the tube you mention.)
At 60ma idle current at 100 volts or above, tube Ra is approx 600 ohms. At the 30ma point of the loadline, the Ra is approx 1000 ohms. The DF is no longer 3, but 1.8 at the 30ma point. (This means a peak to peak current swing of 30ma to 90ma. One can figure the output power from there.)
At the 20ma point, at 100 volts or above, results in an Ra of approx 1200 ohms, double the 600 ohm Ra at 60ma. This means that a DF of 3 now becomes a DF of 1.5 at 20ma.
(This means the current swings between 20ma and 100ma, with 60ma as quiescent.)
If the plate current is allowed to drop to 10ma during a portion of the cycle, the Ra is approx 1450 ohms. DF now becomes 1.25. (peak to peak swing of 10ma to 110ma.)
At 5ma, the Ra increases to approx 2000 ohms, or nearly 3 times that at 60ma. Df becomes approx 1. (peak to peak swing of 5ma to 115ma.)
As the tube approaches cutoff, the Ra rises towards infinity till the tube isn't actually conducting.
PP has virtually no drop off of DF, except because of variations in individual tube characteristics.
PP therefore does not offer such a compromise in Damping factor as SE operation does.
Previous Topic: Polarized non-polar caps
Next Topic: Need 15 watt plus SET design for DIY?
Current Time: Sat Nov 07 23:50:08 CST 2026
