Home » Audio » Thermionic Emissions » Looking for good 20 watt amp design to drive Jordan TL's?
Damping factor - SE vs. PP [message #11220 is a reply to message #11219] Tue, 11 October 2005 06:45 Go to previous messageGo to previous message
Just to add - PP amp doesn`t have a larger damping factor (or lower output resistance) then SE amp per se, but from the fact that most PP amps have a global negative feedback loop and SE amp mostly do not.
If we have a typical 300B SE amp with say Ra=3k, we can expect DF~3 without neg. feedback, or DF=Ra/(rp+Rw). We can express DF on the secondary side, like ratio DF=Rsp/Rout, where Rout is rp+Rw (anode resistance and windings resistances "reffered" to the secondary).
Then, we can have 300B PP amp, class A, say with Raa=6k. Primary reflected impedance is doubled, but we now have two output tubes, and DF=Raa/(2rp+Rw). We can see that in both examples (SE & PP) we have about the same DF.
In fact, if we use typical UL PP output stage coupled with somewhat lower Raa (AB1 amp), then we can expect maybe DF~1 without feedback.
Simplified, and there`s a more about PP/SE things...
Previous Topic: Polarized non-polar caps
Next Topic: Need 15 watt plus SET design for DIY?
Current Time: Sat Nov 07 23:50:16 CST 2026
