Home » Audio » Thermionic Emissions » 2A3 Upgrade (Paramour)
Iron, Push Pull [message #10900 is a reply to message #10568] Sun, 19 December 2004 17:40 Go to previous messageGo to previous message
Hey-Hey!!!,
You don't need any particular type of Iron. Stay class A, choke input PS, and no 'lytics. Of course good Iron helps a lot...
You are looking at the last amp I have assembeled/designed. Part of the Iron is salvaged from one sort of PS or another. Outputs are Heyboer's copies of the Peerless S265 with a few mods for this particular circuit. The finals are HY69's, a Thoriated Tungsten DHTetrode. The front end is an E-Linear cascode diff amp. Ec2 referenced to the cathode node instead of the usual ground through a voltage divider...
It makes about 15 watts.
regards,
Douglas
....damn Thrintun!
Previous Topic: tube sources needed
Next Topic: possible group build
Current Time: Mon Oct 05 16:30:06 CDT 2026
