Home » Audio » Silicon Valley » AUSSIE 15W CLASS A AMP
AUSSIE 15W CLASS A AMP [message #10304] Sat, 12 March 2005 01:39 Go to previous message
Howard is currently offline  Howard
Dear Semiconductor forum.
This is a nice amp available in kit form, from Perth WA. It uses a low voltage regulated supply (outboard). I added a couple of extra filtering caps. The amp case was built using 3mm plate steel. Its heavy but certainly helps with both cooling and shielding. I am able to use solid core sterling silver on the input and its completely hum free.(infact silver is used for all connecting wires) The only obvious problem is the fact that I have no soft start circuit. I should add a switch to mute the speakers on switch on.
Sounds as sweet as pie! but needs a good quality active pre to drive.
The power supply can get quite hot on balmy evenings in the sub tropics??
Kits available at
http://www.altronics.com.au/index.asp?area=item&id=K5109
Happy listening
Howard
Previous Topic: Bargain sub amp
Next Topic: Auricaps
Current Time: Fri Oct 16 22:21:16 CDT 2026
