Posted by Wayne Parham [ 70.128.97.44 ] on September 03, 2006 at 16:09:30:
In Reply to: Larger Driver posted by Zene on September 03, 2006 at 01:17:51:
Model it using Hornresp. You can probably find a driver that will work for you. Just by looking at it, I think a JBL 2012 or Eminence Delta 10 would probably sound good on that horn. Might be worth a try.
[ PiSpeakers Forum ] [ Help ]
