Posted by Wayne Parham [ 70.234.105.201 ] on June 10, 2006 at 11:29:49:
In Reply to: Re: bass as per enclosure posted by j.luis cruz . on June 09, 2006 at 19:08:32:
That's a common misconception - bass doesn't come solely through the ports. Bass sound pressure comes from the front of the cone just as it does from the back. The rear wave is tuned by a Helmholtz resonator which loads the cone at bass frequencies, but most of the sound you hear comes from the front. Only a narrow range in the bottom octave comes through the ports.
[ PiSpeakers Forum ] [ Help ]
