Posted by spkrman57 [ 24.33.234.32 ] on October 07, 2005 at 08:10:21:
In Reply to: Re: ** Pi chart request ** posted by Wayne Parham on October 06, 2005 at 23:10:11:
Wayne,
Have you ever run a impedance curve test to see? Would be quick and easy with WT2 from PE.
I take it from your last post that the staggered impedance of the 2 drivers flatten out the impedance and that there is probably only a few occurences where the impedance would drop below say 6 ohms, right???
It also seems if the above is true, then a zoebel is not required which reduces the parts count also. That would be very convenient and save some $$$ in the long run.
Now it seems the only problem I have to breadboard this system is to move things around in the house(easier said than done!) The one thing different for me will be trying the JBL 2242 18" in a 9 cubic ft box tuned to 30hz, I was the lucky person in the right place and the right time to get these cabinets built by a "JBL" guru who wants to remain anonymous. They have 2' x 4' bracing and 2 x 6" dia by 13.5" ports. This driver is currently doing sub duty and kicks butt! I can never listen to a 12" or lame 15" sub ever again!!!
Later, Ron
[ PiSpeakers Forum ] [ Help ]
