Posted by Adrian Mack [ 202.137.97.93 ] on June 17, 2004 at 08:53:13:
In Reply to: Re: JBL L5 mid-horn posted by Wayne Parham on June 17, 2004 at 06:00:15:
The gaskets you're talking about are different to what Mr Edgar used though. Edgar's ones are just spacers, not full gaskets. I believe it just uses 4 spaces on the driver to make a physical gap between driver and mounting plate, and you can see the gap through the side (unlike a gasket where its all covered).
[ PiSpeakers Forum ] [ Help ]
