Home » Sponsored » Pi Speakers » Pi 3 subwoofer
Pi 3 subwoofer [message #73227] Mon, 09 July 2012 06:37 Go to previous message
48h350 is currently offline  48h350
Hi Wayne, you sent me the plans for the Pi 3 sub.
Unfortunately the shipping to Australia is just about as expensive as the driver-Eminence Lab 12-itself, so i am looking for alternatives.
You did approve, in the past,the use of a car sub from JBL: GTO 1214 TD .
So I am thinking of using this driver to build the subs ( 2 )
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/BoxesandParameters/GTO1214TD.pdf
I found this piece of software to work out dimensions,port length etc. http://www.ajdesigner.com/fl_subwoofer/subwoofer.php
Is this software good enough to design the enclosure or would you use something else?
What alignment would you recommend?
Would you build a sub just as wide as the Pi 4 and use it as a stand?
Thanks for your work.
Massimo
Previous Topic: 4pi plans
Next Topic: Pi7 Mid Horn Question's
Current Time: Thu May 16 12:32:59 CDT 2024
