Home » Audio » Thermionic Emissions » PSUDii tips
PSUDii tips [message #8792] Mon, 31 January 2005 15:56 Go to previous message
Hey-Hey!!!,
I just got the output voltage tuning done for the filament supplies on my new linestage design. L-C and L-C-R-C. They matched PSUDii sim predictions to a few percent.
Critical stuff is the input voltage and component DC resistance. The input voltage should be the unloaded voltage measured when line voltage is applied and the winding in question is otherwise unloaded.
DC resistances of just the secondary have been acceptable. With the step-down ratios encountered with filament supplies, the small primary resistance appears even smaller.
The ESR of the capacitors seems to make very little difference. The data is either available from the manufacturer or guess. Tens of mOhms to a tenth of an Ohm seems to be a reasonable bet for a 'lytic. Go for the minimum allowable for good film caps.
regards,
Douglas
Previous Topic: Quick and simple formulae for Ra
Next Topic: Proud Papa Syndrome (Check out my new amp...)
Current Time: Wed May 15 08:05:38 CDT 2024
