Home » Audio » Thermionic Emissions » Today's Puzzler
Today's Puzzler [message #8677] Wed, 12 January 2005 12:52 Go to previous message
TubeCraft is currently offline  TubeCraft
Noticed the new amp I built is short on bass. I fire up the test tone CD, and sure enough, no reponse at 100hz. (Response at 1khz and 10khz seems pretty normal.)
Using a plain old VOM, I trace good response (test tone at 100hz) to the socket grid connection of the driver tube, a 5687. The 5687 has 170v on the plate (pin1), the cathode is at 7v(pin 3), running at 14.7ma. I measure a 5v RMS signal at the grid pin socket connection (pin 2).
There is little or no signal appearing at the plate (91mv).
Swap in several different tubes, 5687, 7044 no change.
Any ideas?
Rk=475r (bypassed 220uf) Rl=7k5 Grid=100k gain pot
Previous Topic: Bypassing Caps
Next Topic: Do You Know Which Is The Best 845 Tube?
Current Time: Wed May 15 12:18:14 CDT 2024
