Home » Audio » Thermionic Emissions » Tweaker "universal" mono amps
Tweaker "universal" mono amps [message #11175] Sat, 30 July 2005 19:28 Go to previous message
Howard is currently offline  Howard
Dear Forum.
The ally boxes are away getting powder coated.They should be ready Tuesday (charge $70) Typically I have already made a couple of mistakes. The OPT needs rotating to reduce hum. Luckily the base is square so this means one hole. I should have three speaker connections per box (one for 16ohm tap). At least one switch needs changing. Earle has been a big help guiding me with all sorts of suggestions.
I have put a wiring diagram together using VISIO and all further pictures and changes will be appearing on this producer file.
http://www.eastmarinedrive.com/contents/download/media/element_files/Default.htm
I must be a bit of a nerd! I should be able to add some home movies later
I am very keen to get going on the soldering iron but I am not that experienced and feel like I have to check everything
Have a good weekend
Howard
Previous Topic: Pull pin...
Next Topic: Chicago Audiofest
Current Time: Sat May 11 04:24:26 CDT 2024
