Home » Sponsored » Pi Speakers » Crossover Doc Spcie models
Crossover Doc Spcie models [message #35497] Thu, 14 March 2002 15:13 Go to next message
dbeardsl is currently offline  dbeardsl
Wayne,
Thanks for the info.
I'm probably not doing something right.
I used your exact spice model in the crossover doc for the Delta 15 and the psd2002 with a simple firt order butterworth.
I put the current source across node 5 and 0 like you said, and measured the voltage at node 6 and 1. I get something cloe to yours, but not quite the same.
Here is the spice model...
Delta 15 and PSD 2002 with 1st order Butterworth
! First order network
L2 5 6 0.6mH
C2 5 1 16uF
! woofer virtual circuit (Eminence Delta 15)
! voice coil reactance
R3 6 7 6.9
L3 7 9 0.86mH
! mechanical reactance (40Hz, Q=6.56)
C5 9 0 400uF
L5 9 0 40mH
R5 9 0 65.6
! tweeter virtual circuit (Eminence PSD2002)
R4 1 10 6.6
L4 10 11 0.1mH
! mechanical reactance (on H290)
C6 11 12 20uF
L6 11 12 2mH
R6 11 12 100
C7 12 13 10uF
L7 12 13 1mH
R7 12 13 100
C8 13 0 5uF
L8 13 0 0.5mH
R8 13 0 100
R9 11 0 20
C9 11 0 50uF
I 5 0 AC 1
And the link is the graph I get.
Am I doing the graph wrong.. I expected it to be exactly like the one pictured, I tried different voltages, but of course I get the same thing, just a little up the scale.
Re: Crossover Doc Spcie models [message #35498 is a reply to message #35497] Thu, 14 March 2002 15:48 Go to previous messageGo to next message
I looked at your graph and it appears to be similar, except you are using a different scale. For the Frequency [X] axis, I use the scale factors, linear axis, min 0, max 20000, increment 5000, minor tics 4, major grid solid, minor grid dot. And for the amplitude [Y] axis, I use the factors linear axis, min -50, max 0, increment 10, minor tics 4, major grid solid, minor grid dot.
Your tweeter curve looks the same as mine, and in the woofer curve, I can see the two peaks caused by your woofer cabinet. Good job!
My Cabinet? [message #35505 is a reply to message #35498] Fri, 15 March 2002 08:37 Go to previous messageGo to next message
cool, I'll mess with the scale. Though I'm not sure how you got your graph to show only negative values, is there some way to graph equations? like (V[6] - V[5])?
I suppose I could use the real spice... I tried once and couldn't get the graph anywhere close to yours. Though I use it to lay out the circuits, then just grab the netlist which is the spice model.
But How did a cabinet factor in here? I copied this straight out of the crossover doc. There isn't anything there to simulate a box...
How would you simulate a box anyway?
Re: My Cabinet? [message #35508 is a reply to message #35505] Fri, 15 March 2002 11:05 Go to previous message
Some of the models have a parallel resonance which is used to simulate the behaviour of the box. I put this in some of the models, but disabled it by commenting it out. You can uncommented this box resonance or make your own.
Previous Topic: Using APT-50 or 80 or 130
Next Topic: Active crossover vs passive crossover
Current Time: Fri May 03 17:20:18 CDT 2024
