Home » Audio » Swap Meet » Looking for tube sockets- please help!!
Looking for tube sockets- please help!! [message #32358] Fri, 22 October 2004 03:16 Go to next message
Dieter is currently offline  Dieter
Hello tube freaks!
For my Nixie Tube Tester I'm looking for some special tube sockets.
I am glad about every hint where to get them and for every offer.
Pictures of the sockets you can find here:
http://www.tube-tester.com/sites/nixie/socket/nixie-sockets-search.htm
Here the description of the sockets:
B17A Socket:
Description: 17pin, Pin diameter=1.02mm (0.040"), Pin circle diameter=18.2mm (0.718"), Pin
spacing=20°
Used for: ZM1200 Pandicon, GR10H Nixie Tube
B26A Socket:
Description: 26pin, Pin diameter=1.02mm (0.040"), Pin circle diameter outer=18.2mm (0.718"),
Pin circle diameter inner=11.1mm (0.437"), Pin spacing(outer)=20°
Used for: GR10J Nixie Tube
B27A Socket:
Description: 27pin, Pin diameter=1.02mm (0.040"), Pin circle diameter outer=18.2mm (0.718"),
Pin circle diameter inner=11.1mm (0.437"), Pin spacing(outer)=20°, one pin in the middle
Used for: Z572S Dekatron Tube
SK-116 Socket:
Description: 11pin, Pin diameter=0.45mm (0.018"), Pin circle diameter=9.4mm (0.370"), Pin
spacing=30°
Used for: ZM1120, ZM1122 Nixie Tube
SK-176 Socket:
Description: 13pin, Pin diameter=0.51mm (0.020"), Pin circle diameter=oval
Used for: NL-4998, B-4998 Nixie Tube
SK-207 Socket:
Description: 14pin, Pin diameter=0.45mm (0.018"), Raster: see Picture!!!
Used for: ZM1330 Nixie Tube
TSB-14P Socket:
Description: 14pin, Pin diameter=1.02mm (0.040"), Pin circle diameter=20mm (0.790"), Pin
spacing=22,5°
Used for: CD11, CD14, CD94, GR-201 und GR-211 Nixie Tubes
11 pin Russian Socket:
Description: 11pin, Pin diameter=1.02mm (0.040"), Pin circle diameter=9,4mm (0.370"), Pin
spacing=30°
Used for: russian IN-2 und IN-8 Nixie Tubes
Thank you very very much for every response!
don't hesitate to write me:
Dieter Wächter
email: smile1973@web.de
Thanks for your help!
Re: Looking for tube sockets- please help!! [message #32359 is a reply to message #32358] Fri, 22 October 2004 12:05 Go to previous messageGo to next message
metasonix is currently offline  metasonix
I would recommend Jan Wuesten, he sells a lot of surplus Russian and European tube sockets. The stuff you're looking for is mostly VERY difficult to find. I have a big sack of 14-pin Nixie sockets (same size as 9-pin miniature tube, but with 10 pins in a circle and 4 more in the center).
www.askjanfirst.com
BTW, the 26 pin sockets were most often used with Beam-X counter tubes.
Re: Looking for tube sockets- please help!! [message #32366 is a reply to message #32359] Tue, 26 October 2004 23:41 Go to previous message
Hello!
I'm interested in your sockets!
How many?
How much?
are all 14 pins equipped?
Thanks
Dieter
Previous Topic: Grado SR-225 Headphones
Next Topic: C ES Vintage and Classic Audio Show
Current Time: Thu May 09 17:29:53 CDT 2024
