Home » Audio » Group Build » troubleshooting continued.
Re: How much difference? [message #30928 is a reply to message #30927] Fri, 11 March 2005 09:01 Go to previous messageGo to next message
an amount comparable to the resolution of the meter. basically not at all. The 9V is enough headroom for the circuit to regulate.
regards,
Douglas
Re: 198DCV from B+ to B- for Guinevere [message #30929 is a reply to message #30926] Fri, 11 March 2005 09:19 Go to previous messageGo to next message
Will do thanks C.
Re: that's the funny part... [message #30930 is a reply to message #30922] Fri, 11 March 2005 09:20 Go to previous messageGo to next message
No problem; you are probably right something is amiss. I will hunt it down and terminate with extreme prejudice.
Re: that's the funny part... [message #30931 is a reply to message #30930] Fri, 11 March 2005 09:36 Go to previous messageGo to next message
it does not have to be an overt maistake either. Be thorough, and methodical, and it will probably quickly come to light.
regards,
Douglas
Re: that's the funny part... [message #30932 is a reply to message #30931] Fri, 11 March 2005 11:42 Go to previous message
does a bad ground from pot to ground buss count as a venal sin or a mortal sin? Hunted that sucker down and now things look pretty good.
Entering the making sound phase.
Previous Topic: Carbon comp vs carbon as grid stoppers
Next Topic: Call this evening
Current Time: Wed May 15 16:34:03 CDT 2024
