Home » Audio » Group Build » Wiring the variable resistor
Wiring the variable resistor [message #30599] Sat, 19 February 2005 11:51 Go to next message
The variable resistor has three pens, but the schematic shows only two hook up points. What I did is hook the two pens up that show variable resistance when the screw is turned. The third pen is not used. Is this correct.....Colin
Wiring the variable resistor [message #30600 is a reply to message #30599] Sat, 19 February 2005 12:15 Go to previous message
hey-hey!!!,
You can wire it two ways:
one. wire to one end and the wiper.
two. wire to a connected wiper/end terminal and the other end terminal.
Pick the end terminal so that the twisting direction fits your own convention for increasing regulated current. It isn't all that important, save for making sure both are done the same way.
Option 2 also leaves a guaranteed resistance should the wiper contact fail. I don't see this as all that big a threat, and don't see catastrophic damage happening if it does fail.
I suggest option 2.
regards,
Douglas
Previous Topic: Psud II / PC problems
Next Topic: Can someone spot me a bleeder resistor for the PS cap
Current Time: Fri May 17 19:12:35 CDT 2024
